2 Pages12>
one80two
#1 Posted : Sunday, November 29, 2009 12:23:04 AM(UTC)
one80two
I'm a real novice at this, bear with me.
My dryer recently started blowing cold air only, so I took the heating element to a local appliance store and they told me I needed to replace the thermal cutoff. I did that, hooked everything back up exactly but now when I push start the breaker trips. I also noticed that the element is always on, even when not running. I checked it to make sure none of the coils were touching the case causing it to ground. I then unplugged the two wires that connect to the element and the dryer ran fine. If I plug them back up again it trips. What's wrong?
#2 Posted : Sunday, November 29, 2009 1:55:13 AM(UTC)
Sounds to me like a grounded element. You cannot always find the short visually re: a cracked insulator etc.
Check it with a meter.
Unplug the unit and remove both wires from the heating element.
Measure the element usually around 10 ohms.
Then check each heater connector to the frame, both should be infinite ohms.
one80two
#3 Posted : Sunday, November 29, 2009 2:41:26 AM(UTC)
one80two
That's one thing I do need, a meter.
#4 Posted : Sunday, November 29, 2009 4:40:05 AM(UTC)
NOTE: I use mine constantly around the house and in the garage.
one80two
#5 Posted : Sunday, November 29, 2009 7:48:30 AM(UTC)
one80two
I will go purchase a multimeter, but one quick observation. The heating element has two wires that plug into it at the bottom, which I suppose run from the motor. If I only plug the one on the left in, the dryer will run and the heating element will shut off as long as it's on the "OFF" position. When I plug both up, it trips the breaker.
#6 Posted : Sunday, November 29, 2009 8:46:24 AM(UTC)
Usually one side of the heater goes to a centrifugal switch on the motor and then to one side of the line. This switch closes when the motor is rotating and provides the heater with power. It is there to ensure that the heater does not get hot without air blowing over it.
The other side goes through the thermostats and a set of timer contacts to the other side of the line. Completing the 240 volt circuit.
I cannot really say what is going on here.
Note if the centrifugal switch contacts are welded together or the mechanism on the motor which closes the switch is not resetting, the heater will get power whenever the unit is plugged in other than at Off. But this should not blow your breaker.
It will regulate the temperature using the hi-limit thermostat, till this thermostat's contacts weld together and then it will blow the thermal fuse.
one80two
#7 Posted : Sunday, November 29, 2009 9:10:49 AM(UTC)
one80two
I think I've discovered the culprit but not sure what to do. I'll try to explain this as best that I can.
If I hook everything up to the element but sit it on the floor the dryer runs fine. The element doesn't heat up until I push start and everything runs like normal.
When I seat the top of the element into the hole that leads into the drum and then turn it on, boom tripped breaker. I'm so perplexed.
The cage that holds the element appears to be in good condition and I don't notice anything strange on the opening to the tumbler. This has to be what's grounding it though right?
#8 Posted : Sunday, November 29, 2009 12:28:15 PM(UTC)
Yes it does sound like the element is grounded to the heater case.
one80two
#9 Posted : Sunday, November 29, 2009 6:02:51 PM(UTC)
one80two
Do I need a new heater case? Why would it only do it when angled up into the dryer?
#10 Posted : Monday, November 30, 2009 12:25:26 AM(UTC)
I could not find the parts for your unit using the given model number. I looks like it is short at least 3 numbers. But on most units you would need a new heater assembly.
Because when it touches the machine frame it completes the circuit as the frame is grounded back to the electrical panel.
When hanging loose it is floating and the case becomes live but there is no where for the current to go.
Guest (5)
Kenmore dryer trips breaker when door open (Dryer Repair)
by slaterjay 2/13/2018 5:09:53 PM(UTC)
Electric dryer trips breaker when heating (Dryer Repair)
by katflea 7/31/2015 4:46:04 PM(UTC)
Dryer Trips Breaker (Dryer Repair)
by Mrvin 2/26/2015 1:52:18 PM(UTC)
whirlpool dryer trips breaker during cool down (Dryer Repair)
by olpdawg 7/7/2014 6:39:12 PM(UTC)
Dryer trips breaker immediately (Dryer Repair)
by Bigtx 2/16/2013 11:08:02 AM(UTC)
Gas dryer trips breaker (Dryer Repair)
by lightninskyhop 6/26/2012 6:26:10 PM(UTC)
gas dryer trips breaker when rying to heat (Dryer Repair)
by garrywith2rz 9/30/2009 12:41:02 PM(UTC)
Dryer trips breaker (Dryer Repair)
by rsmotorsports 4/6/2009 3:59:58 PM(UTC)
by dayeaw 2/23/2009 4:00:00 PM(UTC)
gas dryer trips breaker (Dryer Repair)
by cerriel 2/20/2009 4:24:09 AM(UTC)
GE dryer trips breaker as soon as I turn it on (Dryer Repair)
by the adam 2/4/2009 3:01:41 PM(UTC)
Dryer Trips Breaker with wet clothes (Dryer Repair)
by msElmo 9/8/2008 7:44:07 AM(UTC)
2 Pages12>
