MarthaJ
#1 Posted : Tuesday, November 24, 2009 3:28:04 PM(UTC)
MarthaJ
The Whirlpool washer has a fabric softner dispenser attached at the top of the agitator. Is it necessary to remove the dispenser before pulling up the agitator? If so, how is the dispenser removed ? The dispenser will not turn. Don't know whether the dispenser is seized or does not separate from the top of the agitator.
Thanks.
Martha
sidfink43
#2 Posted : Wednesday, November 25, 2009 5:40:33 AM(UTC)
sidfink43
Hi Martha
The exploded view of your machine does not show a dispensor, but if you have one it should just lift out. There may be a lot of gunk which is making it difficult, but apply pressure and it should come off. Just be careful it does not release all at once and bop you in the face. (Been there, done that)
You will then find a plastic cap which will come out, and underneat that is a bolt which you can remove with a socket wrench and an extension. Should be 7/16" head.
The agitator will then left out, but again it may be hard to do from laundry gunk.
Click on your model number to see an exploded view of the agitator.
Good luck.
MarthaJ
#3 Posted : Friday, November 27, 2009 9:36:52 AM(UTC)
MarthaJ
MY washer model LA5600XT is not in your database. I have only used the dispenser once, then attempted to remove it to rinse it out. But was unable to remove it. Most likely it was stuck when it was delivered.
Martha
sidfink43
#4 Posted : Friday, November 27, 2009 10:09:32 AM(UTC)
sidfink43
On some models there is an aqua plastic ring that must be moved up to release the fabric softener. See if there is one on yours.
Here is an exploded view of what should be your model.
Agitator, basket and tub replacement parts for WHIRLPOOL LA5600XTF0 | AppliancePartsPros.com
If you cannot get it off then I have no other suggestion but breaking it, which I hate to suggest.
MarthaJ
#5 Posted : Sunday, November 29, 2009 5:58:44 AM(UTC)
MarthaJ
11/29/2009
I found the full model number on the plate attached to the washer LA5600XTW0. I was using the number from the user manual which was not complete.
I removed the softener dispenser. Up near the top of the dispenser is a slight rim. I used a putty knife to lift up on the dispenser at the rim and it came out. It has small plastic protrusions that secure it in the opening.
It is 6 1/2 inches in length. Wide at the top and tapered at the bottom. Someone with a firm grip can probably just pull up on it to remove it. Also it's kind of wide at the top for the average female hand.
Thank you much.
Martha
sidfink43
#6 Posted : Sunday, November 29, 2009 6:13:30 AM(UTC)
sidfink43
Great, glad you got it off and if you need any more help just post.
GE Stacked washer dryer - Agitator Removal (Dryer Repair)
by Guest 5/31/2021 10:26:51 AM(UTC)
Kenmore 20022011 agitator removal (Washer Repair)
by d0ugparker 3/18/2015 8:46:07 AM(UTC)
kenmore agitator removal - bolt turns but won't come out (Washer Repair)
by kimkim 3/2/2015 9:25:47 AM(UTC)
Amana agitator removal (Washer Repair)
by Max Strasser 8/6/2014 11:09:33 AM(UTC)
Agitator Removal (Washer Repair)
by fourspots 5/3/2013 8:51:25 AM(UTC)
Older Maytag Washer Agitator Removal (Washer Repair)
by rjhornak 4/20/2012 10:40:17 AM(UTC)
Agitator removal (Washer Repair)
by kenziegranny 2/12/2012 7:36:24 AM(UTC)
by cutthroattrout1 1/4/2012 1:26:48 AM(UTC)
agitator removal steps; is washer lid removal required (Washer Repair)
by tomdrzich@hotmail.com 8/11/2011 5:36:48 AM(UTC)
by sabado 1/14/2011 6:22:25 PM(UTC)
by rpflynnsr 12/21/2010 11:13:40 AM(UTC)
by engcash 10/20/2010 11:01:54 AM(UTC)
Hotpoint agitator removal (Washer Repair)
by dleatherbu 10/10/2010 10:40:20 AM(UTC)
1980s whirlpool agitator removal (Washer Repair)
by billhuber 10/4/2010 5:20:06 PM(UTC)
by BARDOME' 9/6/2010 11:36:27 AM(UTC)
