cocm
#1 Posted : Wednesday, February 20, 2008 2:42:56 PM(UTC)
cocm
I inherited a Maytag gas range. Three of the four burners work fine. However, when I turn on right rear burner, right front ignitor sparks instead of rear and no gas is released to either front or rear burner.
#2 Posted : Wednesday, February 20, 2008 3:47:01 PM(UTC)
All four burner igniters are on the same circuit and should spark wherever burner is turned "on".
Did you hear the whistling sound when the right rear burner was turned "on"?
Check the right rear burner igniter for cracked and/or broken ceramic insulation.
Remove the burner (turn it CCW) and check for broken and/or loose wires.
Post your findings.
cocm
#3 Posted : Thursday, February 21, 2008 2:46:20 PM(UTC)
cocm
Problem solved; control module was defective.
#4 Posted : Thursday, February 21, 2008 3:56:10 PM(UTC)
I'm glad you were able to fix it.
cocm
#5 Posted : Saturday, February 23, 2008 2:38:29 PM(UTC)
cocm
Gene:
Thanks for responding. I appreciate the help.
COCM
rkeller
#6 Posted : Saturday, February 23, 2008 5:41:28 PM(UTC)
rkeller
hello,
I have a whirlpool gas dryer Model # LGR8648PW.
i belive the problem is with the igniter but not sure.
Burner wont ignite (Oven Repair (including Ranges and Cooktops))
by milardo 6/1/2012 6:54:13 AM(UTC)
