I have a GE Profile GAs RAnge, MOdel #PGB918SEM1SS, that is less than 5 years old. One of my burners wont iginite. There is clicking when I turn the knob. All other burners ignite just fine. Any suggestions? Thanks
Groups: APP Team
Hi. Remove the burner and clean it well, clean the spark ignitor (make sure that ceramic part of it is not cracked). Using the needle or the thin wire clean the orifice inside the burner's opening.
Thank you. Post the results.
Simon.
I cleaned the burner and replaced the ceramic spark ignitor to no avail. It still doesnt light although the other 4 do.
Groups: APP Team
Hi. Can you see the spark at the ignitor? Check if you can light the burner with match. If the burner lights locate the spark module inside the control panel, trace the wire to the one in question and switch it around with the good one. The problem could be the module or the hi voltage wire to the ignitor. The spark module Part number: WB13K10019
