puffinboy
#1 Posted : Monday, February 18, 2008 8:57:02 AM(UTC)
puffinboy
the drain pump is growling and making quite a racket when the machine is running. Any way to repair or do I just replace?
#2 Posted : Monday, February 18, 2008 4:59:07 PM(UTC)
Remove the bottom panel.
Remove the filter from the drain pump and check for a foreign objects inside. Be prepared for some water on the floor.
For more accurate advise I need the complete model number of the washer.
puffinboy
#3 Posted : Tuesday, February 19, 2008 5:04:36 AM(UTC)
puffinboy
Hi Gene,
The Whirlpool model is GHW9100LW.
I cleaned out the filter, some dirt and grease, but other than that there wasn't much in there.
#4 Posted : Tuesday, February 19, 2008 7:15:41 AM(UTC)
Sounds like the drain pump has to be replaced.
- The part number for the drain pump is AP3953640
Here are the break down diagrams for the Whirlpool washer Model GHW9100LW0
