the drain pump is growling and making quite a racket when the machine is running. Any way to repair or do I just replace?
Remove the bottom panel.
Remove the filter from the drain pump and check for a foreign objects inside. Be prepared for some water on the floor.
For more accurate advise I need the complete model number of the washer.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Remove the bottom panel.
Gene. Hi Gene, The Whirlpool model is GHW9100LW. I cleaned out the filter, some dirt and grease, but other than that there wasn't much in there.
Sounds like the drain pump has to be replaced. - The part number for the drain pump is AP3953640 Here are the break down diagrams for the Whirlpool washer Model GHW9100LW0Gene.
