banasiakt
#1 Posted : Sunday, November 15, 2009 3:22:33 AM(UTC)
banasiakt
Compressor and fan in freezer not running. Unplugged over night and still not working.
#2 Posted : Sunday, November 15, 2009 4:01:57 AM(UTC)
You are short at least 3 digits from the end of the Model Number.
Parts are here
Replacement parts for FRT18KG3 models | AppliancePartsPros.com
Sounds like you are stuck in a defrost cycle.
Turn the cam on the defrost timer to see if the unit will start up.
If it does replace the defrost timer.
banasiakt
#3 Posted : Sunday, November 15, 2009 4:13:53 AM(UTC)
banasiakt
I did forget the last 3 digits. Model # is FRT18KG3WO. Where is the defrost timer on my Frigid.
#4 Posted : Monday, November 16, 2009 5:00:15 AM(UTC)
Often it is mounted in the top console in the fresh food section.
If you look up there should be a hole which will let you rotate the defrost timer cam.
Refrigerator and freezer not working (Refrigerator & Freezer Repair)
by Shalini510 11/17/2011 5:02:36 PM(UTC)
GE Refrigerator and Freezer not working. (Refrigerator & Freezer Repair)
by Tamaziuk 7/5/2011 10:21:50 AM(UTC)
