Compressor and fan in freezer not running. Unplugged over night and still not working.
THIS FORUM IS DEAD!!!!!!! |
I did forget the last 3 digits. Model # is FRT18KG3WO. Where is the defrost timer on my Frigid.
Often it is mounted in the top console in the fresh food section.
If you look up there should be a hole which will let you rotate the defrost timer cam. |
