The lights on both the refrigerator and freezer are working, but neither side stays cold. If I try to increase the temperature setting I hear it kick on, but then it stops working. Any suggestions?
Originally Posted by: Shalini510  The lights on both the refrigerator and freezer are working, but neither side stays cold. If I try to increase the temperature setting I hear it kick on, but then it stops working. Any suggestions? LOOK IN FREEZER FOR FROST BUILDUP ON BACK OF FREEZER. THAT INDICATES THAT THE EVAP COIL IS ICED UP. IF SO THE DEFROST HEATER IS BROKEN. ON MY SIDE BY SIDE REFRIG IT WAS NOT DIFFICULT TO REPLACE.
Are all the fans running and the compressor running?
