OkieChic
#1 Posted : Wednesday, October 21, 2009 7:43:06 AM(UTC)
OkieChic
My washer began making a terrible noise last night but still spins, drains & agitates(at least long enough for me to get all of the water out). I can best describe the noise as a ratcheting/rattle. Any ideas? I have had a part replaced twice, can't remember what it was called, because my husband has a tendency to overload the washer thus cracking a circular plastic piece. When that has happened before the washer would not do anything. Wasn't sure if that could be the case this time or not. Thanks!
#2 Posted : Wednesday, October 21, 2009 3:19:39 PM(UTC)
What is the complete model number of the washer?
OkieChic
#3 Posted : Wednesday, October 28, 2009 7:55:35 AM(UTC)
OkieChic
Model #110.20852991
Serial #CL0603295
Type 111
Amps 10
Volts 120
Hz 60
Any suggestions would be greatly appreciated!
#4 Posted : Wednesday, October 28, 2009 3:56:59 PM(UTC)
The first thing I would do is remove the washer cabinet and the motor coupling (#13 on the diagram) and check the coupling. Most likely it's cracked. The instructions are attached to the reply.
- The motor coupling Part number: AP3963893
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 24 time(s).
How to remove the pump.doc (25kb) downloaded 11 time(s).
How to replace the motor drive coupling.doc (25kb) downloaded 12 time(s).
OkieChic
#5 Posted : Thursday, October 29, 2009 6:32:11 AM(UTC)
OkieChic
Thanks! I will give that a try & let you know how it goes. I appreciate your knowledgable advise!
OkieChic
#6 Posted : Tuesday, November 10, 2009 8:47:55 AM(UTC)
OkieChic
Thanks for your help. My washer is once again in working order thanks to your advise!
#7 Posted : Tuesday, November 10, 2009 10:21:02 AM(UTC)
You are welcome. I'm glad you were able to fix it.
