My washer began making a terrible noise last night but still spins, drains & agitates(at least long enough for me to get all of the water out). I can best describe the noise as a ratcheting/rattle. Any ideas? I have had a part replaced twice, can't remember what it was called, because my husband has a tendency to overload the washer thus cracking a circular plastic piece. When that has happened before the washer would not do anything. Wasn't sure if that could be the case this time or not. Thanks!
What is the complete model number of the washer?
Model #110.20852991 Serial #CL0603295 Type 111 Amps 10 Volts 120 Hz 60 Any suggestions would be greatly appreciated!
The first thing I would do is remove the washer cabinet and the motor coupling (#13 on the diagram) and check the coupling. Most likely it's cracked. The instructions are attached to the reply. - The motor coupling Part number: AP3963893
Originally Posted by: Gene The first thing I would do is remove the washer cabinet and the motor coupling (#13 on the diagram) and check the coupling. Most likely it's cracked. The instructions are attached to the reply. - The motor coupling Part number: AP3963893
Gene. Thanks! I will give that a try & let you know how it goes. I appreciate your knowledgable advise!
Thanks for your help. My washer is once again in working order thanks to your advise!
You are welcome. I'm glad you were able to fix it.
