Hi, The hub plate is broken. I cannot get the hub nut off. I have soaked it over night with wd40, still will not move. How can I get it off? Once hub is off, any parts that should be replaced at this time? A new hub nut, hub seal, split ring, hub washer, anything else. Thanks for your help, Paul
Hi Paul
That nut should be left hand threaded, so that may be part of the cause of your problem. If you already knew that (and you probably did) it is just a matter of working with it to get it off.
As far as anything else is concerned, just take a good look at everything, and clean everything you can.
Good luck.
Thanks for the advice. Knew it was was a left hand thread, but still cannot get it to move. Looks like I'll try cutting the nut off.
Thanks again. Paul.
