jmsnewton
#1 Posted : Wednesday, August 15, 2007 7:54:20 PM(UTC)
jmsnewton
Just finished 7 loads of laundry, and on the last one, the tub wouldn't drain. We checked the drains, and they don't appear to be clogged. So, before we go and buy parts we may not need, how do you determine if the pump is bad, or is there something else that may be involved?
TIA,
joanne
#2 Posted : Wednesday, August 15, 2007 9:47:51 PM(UTC)
Hi Joanne
We might be able to help you but we need the complete model number of your washer.
lizclo
#3 Posted : Tuesday, August 28, 2007 7:04:25 AM(UTC)
lizclo
:confused: please help! my washer is not spinning out enough water from my clothes. what can i do to fix it. i find myself 2 hrs on one load to wash and dry. cant afford to buy a new one right now. liz
#4 Posted : Tuesday, August 28, 2007 8:08:19 PM(UTC)
Hi lizclo
One of the most common cause of such problem is a unbalanced load.
If your washer is shaking during the spin cycle it never will go on full speed. The first thing check if the washer is leveled, then if you see it's shaking, open the lid and redistribute the garments inside.
If it does not work then I need the complete model number of your washer. You can find it under the lid.
Good luck.
lizclo
#5 Posted : Wednesday, August 29, 2007 10:16:53 AM(UTC)
lizclo
thanks for replying so quickly gene,
but it doesnt do any of that. it looks to be running ok just needs to spin twice. i will get that number for tonight.
thanks,
liz
#6 Posted : Tuesday, September 4, 2007 9:45:50 PM(UTC)
Hi lizclo
Are you sure the problem is the washer and not the dryer?
If the dryer vent is clogged up, it takes much longer time to dry. Try to disconnect the vent hose from the back of the dryer and run a couple loads to see how long it takes.
Good luck.
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Maytag washer won't drain with clothes (Washer Repair)
by Guest 7/8/2021 3:20:36 PM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Washer won't drain (Washer Repair)
by jpowell1978 2/23/2017 5:58:30 PM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
by brokenge 2/18/2016 2:32:59 PM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Washer won't drain!!! (Washer Repair)
by Bdelay24 11/5/2015 6:27:01 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
Top load washer won't drain... (Washer Repair)
by Gigler90x 7/28/2015 7:38:09 PM(UTC)
