RNB19
#1 Posted : Thursday, November 5, 2009 8:51:08 AM(UTC)
RNB19
Finished cooking with the oven, pushed the "Clear Off" button and it didn't turn off.
Turned the oven off at the breaker, rechecked last night and same thing.
Gut feel says it is the panel behind the clock, could it be something else?
If it is the panel, is it a job for a DIY'er
#2 Posted : Thursday, November 5, 2009 5:50:44 PM(UTC)
Most likely the problem is a bad control board aka a clock/timer. The model number you posted does not come up. Verify and repost it.
RNB19
#3 Posted : Thursday, November 5, 2009 6:38:49 PM(UTC)
RNB19
Gene, thanks for the reply, it's a Frigidaire Gallery model # NGSE3WZASC
#4 Posted : Saturday, November 7, 2009 12:36:11 PM(UTC)
The control board has to be replaced together with the overlay because it's glued to the control board.
- The control board Part number: AP3693959
- The overlay Part number: AP2126498
RNB19
#5 Posted : Sunday, November 8, 2009 6:53:36 PM(UTC)
RNB19
Thank you, is it an easy replacement a DIY'er can do or does it require a professional?
#6 Posted : Monday, November 9, 2009 1:22:03 PM(UTC)
If you know how to use a simple tools, this part is not too difficult to replace yourself. Power off the range and remove the rear control panel cover. Remove the screws holding the control board and pull it out as far as the wires go. Remove the wires (one at a time) from the old control board and connect them to the new one.
RNB19
#7 Posted : Monday, November 9, 2009 1:24:40 PM(UTC)
RNB19
Thank you again, I appreciate your help.
#8 Posted : Monday, November 9, 2009 2:02:06 PM(UTC)
Guest (7)
Single Range won't turn off (Refrigerator & Freezer Repair)
by shane.family4 8/21/2014 5:16:58 PM(UTC)
Kenmore range won't turn off (Oven Repair (including Ranges and Cooktops))
by laxnkio 2/23/2010 1:10:06 PM(UTC)
Kenmore oven/range won't turn off (Oven Repair (including Ranges and Cooktops))
by JillGaskin 1/14/2009 7:26:24 AM(UTC)
Kenmore Electric Range Won't turn off (Oven Repair (including Ranges and Cooktops))
by carlynew 3/16/2008 3:03:59 PM(UTC)
