rday
#1 Posted : Sunday, November 1, 2009 7:07:27 PM(UTC)
rday
my whirlpool duet will not drain or spin. what could be the problem
sidfink43
#2 Posted : Tuesday, November 3, 2009 3:28:21 PM(UTC)
sidfink43
Look for some tech notes either inside the bottom panel or under the top. They will show you how to put your machine into a test and diagnosis mode. Also clean out the drain pump and drain system.
If you need more info post back the results of your testing and the full model number of your machine as there are several models of the Duet.
Washer wont spin or drain (Washer Repair)
by steelem@myomnitel.com 2/3/2014 10:20:19 AM(UTC)
washer wont spin or drain (Washer Repair)
by hunter02 7/15/2013 10:36:02 PM(UTC)
by dionnaorner 4/11/2013 5:27:51 PM(UTC)
Washer Wont Spin Or Drain (Washer Repair)
by tammy924 1/17/2013 10:11:49 AM(UTC)
dishwasher wont spin or drain (Dishwasher Repair)
by jbenn 6/4/2012 7:12:32 PM(UTC)
My washer wont spin or drain (Washer Repair)
by Elizabeth2323 4/5/2012 5:15:32 PM(UTC)
roper washer wont spin or drain water (Washer Repair)
by michalek 3/28/2011 6:59:22 PM(UTC)
by jcreek 7/22/2008 8:00:15 AM(UTC)
