GKS
#1 Posted : Saturday, February 9, 2008 11:35:38 AM(UTC)
GKS
I have Voltage on both sides of the heating element while the dryer is running and the element tests 9.9 ohms when tested across the posts. but NO HEAT.
My wife says it sometimes heats.
The dryer runs and everything seems to be working properly except the Heat
Any Ideas?
GKS
#2 Posted : Tuesday, February 12, 2008 2:05:18 PM(UTC)
GKS
Wow...no help so far on this site.
I've got 124 volts on one side of the element ( one side to grnd) no voltage coming out of the heater relay. I'm guessing that means I've got a bad relay. The 124 volts coming through the motor is making it to the Heating element but not the voltage through the relay.
Anyone out there? (as he listens to the sounds of crickets)
abbie
#3 Posted : Wednesday, February 13, 2008 3:31:24 AM(UTC)
abbie
check the two fuses/breakers in your elecrtical panel.There should be 240 volts going to the heater.check the high limet thermostat on the heater box to see if it,s closed.If opened replace.
old kenmore fridge click (Refrigerator & Freezer Repair)
by rleescott 7/4/2024 7:07:45 AM(UTC)
Kenmore series 500 brake release problem (Washer Repair)
by walbar1516 6/29/2024 10:20:56 AM(UTC)
Kenmore 800 wahser stop before rinse (Washer Repair)
by Dharmesh8 6/27/2024 4:15:32 AM(UTC)
Kenmore Fridge Supco (Refrigerator & Freezer Repair)
by Tony442 6/23/2024 8:34:01 PM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
Kenmore Elite Commercial#25344723100 (Refrigerator & Freezer Repair)
by Stubblefield 6/13/2024 5:47:53 PM(UTC)
Water leaking from Kenmore Elite 10657789700 (Refrigerator & Freezer Repair)
by Guest 6/8/2024 12:11:48 PM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
Kenmore Washer Hums and Won't spin (Washer Repair)
by dieselgg 5/18/2024 6:29:18 AM(UTC)
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
JP1 on Kenmore / Midea control board (Microwave Repair)
by jenom 4/27/2024 6:43:05 AM(UTC)
Kenmore 500 seris (Dryer Repair)
by Guest 4/24/2024 4:34:41 PM(UTC)
