I have a Kenmore over the range microwave with a Midea control board inside. On the board, there is a 6 vertical pin connection, (3x2), marked JP1 ,it looks like as the usual jumpers pind on computer boards. Anybody has an idea, what it could be for? Thanks!
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Identified the microcontroller,Abov 96F6432 and based on its datasheet, JP1 pins are connected to it's OCD debug programming...dscl & dsda. So it is not a jumper for any settings!
