2 Pages12>
sillyshopper
#1 Posted : Saturday, February 9, 2008 8:02:27 AM(UTC)
sillyshopper
Hi there: Our 8 year old Whirlpool double oven is completely dead. For the first time ever, we tried out the self cleaning cycle and right after the cycle completed, the unit went dead. The last thing I remember seeing on the digital readout during the end of the self clean cycle was "cool", which tells me it went through the entire self cleaning cycle. The door will open, but the lights do not work and the digital panel is dead.
I tried the breaker switch, it looked fine (it shares a 160 amp breaker with our dryer which is working fine).
Please Help!!
#2 Posted : Saturday, February 9, 2008 8:57:38 PM(UTC)
There is the thermal fuse plugged in the control board which has to be replaced.
The thermal fuse
UserPostedImage
Turn off the circuit breaker for the oven.
Open the lower oven door. Remove the screw holding the each side trim (#1 on the oven break down diagram) and remove both side trims by pulling them from the bottom toward yourself and down to release from the control panel tabs.
Remove the screw on each side of the control panel. Pull the bottom of the control panel toward yourself and upward to release it from the side tabs.
Now it's all yours.
- The part number for the thermal fuse is AP3110028
Here are the break down diagrams for the Whirlpool oven Model RBD306PDB1
P.S. To avoid such problems it's better not to use the self clean.
P.P.S. The 160 Amp breaker is way too much. According to the installation instructions an oven and a dryer must have a separate circuit breakers with no more than 30 to 40 Amps.
THIS IS VERY DANGEROUS!
2132mg
#3 Posted : Tuesday, February 12, 2008 4:48:02 AM(UTC)
2132mg
Gene:
please see my post from last week; I would greatly appreciate any help you can give me; it begins "no error codes . . . "
#4 Posted : Tuesday, February 12, 2008 10:53:49 AM(UTC)
Unfortunately this is beyond my expertise.
Maybe somebody else on the forum can help you better.
sillyshopper
#5 Posted : Wednesday, February 13, 2008 9:50:42 AM(UTC)
sillyshopper
:) I just wanted to say thank you for your advice on replacing the thermal fuse as that was the exact problem! We were able to replace the part for around $20 versus having to pay a couple of hundred to have an appliance guy come in. Thank you!
#6 Posted : Thursday, February 14, 2008 11:39:35 AM(UTC)
Hi sillyshopper,
I'm glad you were able to fix it.
scout269
#7 Posted : Sunday, February 12, 2012 11:33:07 AM(UTC)
scout269
man this was so dead on and so simple to repair, Gene is the man:D:D:D:D:D
gloriajw
#8 Posted : Sunday, November 17, 2013 3:13:22 PM(UTC)
gloriajw
"Open the lower oven door. Remove the screw holding the each side trim (#1 on the oven break down diagram) and remove both side trims by pulling them from the bottom toward yourself and down to release from the control panel tabs.
Now it's all yours."
Many thanks! This repair was easy, thanks to you.
wgbergman
#9 Posted : Saturday, January 18, 2014 1:00:52 PM(UTC)
wgbergman
First, thanks so much for this forum.
My issue: Used the Auto Clean. Everything shut down an hour or so into the cycle. Door locked and display blank. I let things cool off and turned off the circuit breaker for about 15 min. Reset breaker with not effect.
Found the forum and tried to find the thermal fuse to see if that might be the issue. Found what I think is the fuse but it does not seem to be blown. See attachment. So is this the fuse? Is it blown? If it looks ok, what is the next thing to check?
Thanks,
Greg
wgbergman attached the following image(s):
#10 Posted : Sunday, January 19, 2014 1:52:31 AM(UTC)
Yes that is the thermal fuse.
You have to measure it with a meter to tell if it is blown.
Should be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
2 Pages12>
