jdeviwith5
#1 Posted : Sunday, October 25, 2009 12:34:42 PM(UTC)
jdeviwith5
dishwasher does not draing. Water left on bottom after cycles. Checked all hoses and they are clear.
Can I remove the smaller pump and have it tested? I do not want to repair this dw if the main motor and pump has a problem?
#2 Posted : Monday, October 26, 2009 4:17:26 AM(UTC)
Replacement parts for GE GSD5800G00WW | AppliancePartsPros.com
Does it drain at all or is it just not draining enough?
Does the solenoid on the left hand side of the main motor/pump assembly activate (plunger pulled down) when the unit goes into drain?
Does the unit wash OK and just the drain is the problem?
If it is not draining fully a common problem is the Piston and Nut valve at the back of the unit under the slotted cover.
You can often feel if the drain pump is running, just be careful that you do not touch the electrical contacts.
You could check it while it is in the unit. Remove the wires from it and check it's winding for continuity. If it is open (infinite ohms) it is toast.
Note this does not totally rule out this pump as the problem.
You could also remove it from the unit, put a line coed on it and check if it runs.
Dishwasher does not drain completely (Dishwasher Repair)
by jlobb2 12/4/2013 2:42:17 AM(UTC)
by jlobb2 12/4/2013 2:40:46 AM(UTC)
Whirlpool dishwasher does not drain (Dishwasher Repair)
by valv00 3/30/2013 5:05:23 PM(UTC)
Jenn Air Dishwasher does not drain completely (Dishwasher Repair)
by jjdoc 6/26/2012 11:41:48 AM(UTC)
Fridgidaire dishwasher does not drain (Dishwasher Repair)
by boblowe 4/25/2012 6:16:26 AM(UTC)
GE GSD500X-72BA Dishwasher does not drain (Dishwasher Repair)
by vitaly 3/2/2012 9:27:07 AM(UTC)
ge dishwasher does not drain (Dishwasher Repair)
by dmtap 5/16/2011 12:16:14 PM(UTC)
GE Triton Dishwasher Does not drain out completely (Dishwasher Repair)
Belarus rkt 7/29/2010 9:36:51 PM(UTC)
by jerry2083 6/26/2010 9:44:04 AM(UTC)
GE Dishwasher does not drain (Dishwasher Repair)
by JohnnyB 2/26/2010 10:25:25 AM(UTC)
Frigidaire Dishwasher does not drain (Dishwasher Repair)
by Jimh64 10/30/2009 1:30:11 PM(UTC)
Dishwasher does not drain after rinse cycle (Dishwasher Repair)
by Michael50 1/23/2009 8:06:25 AM(UTC)
by Sdj 9/25/2007 11:49:33 AM(UTC)
