beachmike
#1 Posted : Tuesday, October 20, 2009 10:59:40 AM(UTC)
beachmike
Hi,our washer will not advance to spin cycle automatically.
it also stays on one speed only.
sidfink43
#2 Posted : Wednesday, October 21, 2009 3:00:55 PM(UTC)
sidfink43
If the machine otherwise works once you manually advance the timer then the timer is probably the problem, but you will have to replace it to be certain. If you want you could clean the contacts and the connection first and see if that helps.
Here is the part.
Part number: AP3131136
Goodspeed98
#3 Posted : Tuesday, March 23, 2010 10:12:27 PM(UTC)
Goodspeed98
may you have a careful check and make sure taat everything in all right ,
Will not advance to spin cycle (Washer Repair)
by momo9767 5/2/2011 9:39:40 AM(UTC)
Washer will not advance to spin cycle (Washer Repair)
by evcollins@bellsouth.net 8/11/2009 3:43:21 PM(UTC)
