Washer will not advance to the spin cycle in any of the wash modes on the timer. If you move or jar the washing machine around a little bit, sometimes the timer will advance to the spin cycle. I thought the timer was bad so I replaced timer with a new one. Same problem exist. Did'nt help at all. :confused: Any good suggestions out there?:)
Probably a bad lid switch AP3100003
Originally Posted by: richappy Probably a bad lid switch AP3100003 Thanks richappy for the suggestion/solution. I will check it out on the next wash cycle.:) evcollins
