evcollins@bellsouth.net
#1 Posted : Tuesday, August 11, 2009 3:43:21 PM(UTC)
Washer will not advance to the spin cycle in any of the wash modes on the timer. If you move or jar the washing machine around a little bit, sometimes the timer will advance to the spin cycle. I thought the timer was bad so I replaced timer with a new one. Same problem exist. Did'nt help at all. :confused: Any good suggestions out there?:)
#2 Posted : Wednesday, August 12, 2009 3:35:40 AM(UTC)
Probably a bad lid switch AP3100003
#3 Posted : Wednesday, August 12, 2009 5:37:00 PM(UTC)
Thanks richappy for the suggestion/solution. I will check it out on the next wash cycle.:) evcollins
