scott_lngly
#1 Posted : Wednesday, October 21, 2009 6:40:23 AM(UTC)
scott_lngly
i just got a decent washer, model#pavt244aww, maytag performa washer and i hooked it up yesterday and started running it, and after it filled up with water it started making a loud buzzing noise, i then put it on the spin cycle to see if i could get the water to drain, still no luck, it was still making the loud buzzing noise,and would not spin or go into any cycle, all it will do is fill up with water, i am wondering if it might be the motor in it? i really dont think its the water pump, but their is always the possibility…. i need help!!!!someone plz help me
#2 Posted : Wednesday, October 21, 2009 2:41:24 PM(UTC)
Tilt the washer back and remove the belt. Check if the pump is moving freely in both directions. Turn the washer On and see how the motor works. Post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG PAVT244AWW | AppliancePartsPros.com
scott_lngly
#3 Posted : Thursday, October 22, 2009 7:45:22 AM(UTC)
scott_lngly
well gene i tilted the washer back and took the belt off the motor spins but, im assuming its the water pump, its not doing anything at all, then i put the belt back on and left it leaning back and the horrible noise was coming from the pump towards the back of the washer, do u think i need a new pump?
#4 Posted : Thursday, October 22, 2009 4:03:44 PM(UTC)
The pump is the culprit. No doubt about it. This is one of the most common problems with those washers. Maytag had redesigned the pump and it should last longer now.
- The drain pump Part number: AP4373022
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Maytag Performa washer fills, drains, spins, but doesn't agitate (Washer Repair)
by shshimo 3/9/2014 8:25:14 PM(UTC)
Maytag Performa Washer loug banging noise when stopping (Washer Repair)
by johncher 2/9/2013 2:43:39 PM(UTC)
Maytag Performa Washer Smoking (Washer Repair)
by Fixineer 1/31/2013 10:22:01 PM(UTC)
Maytag Performa Washer vibrates and walks (Washer Repair)
by Kurt_washer_2012 12/2/2012 5:54:40 PM(UTC)
maytag performa washer (Washer Repair)
by denise57 5/16/2012 9:11:20 AM(UTC)
Rat-a-tat noise from Maytag Performa washer (Washer Repair)
by Inspector Gadget 1/6/2012 3:12:50 PM(UTC)
I think the pump quite on my maytag performa washer (Washer Repair)
by ChevyCowboy 12/9/2011 5:24:18 PM(UTC)
Maytag Performa washer, slow spin speed (Washer Repair)
by hank b 4/18/2011 7:26:54 AM(UTC)
Maytag Performa Washer Will Not Agitate Sounds Like Bad Bearing (Washer Repair)
by plamberty75 1/13/2011 11:26:49 AM(UTC)
Maytag Performa Washer Leaking From Bottom While Filling (Washer Repair)
by mjones61 11/7/2010 11:00:15 AM(UTC)
Maytag Performa washer does not spin (Washer Repair)
by ret2002 8/10/2010 2:05:38 PM(UTC)
Maytag Performa washer timer knob removal? (Washer Repair)
by Albert P 1/20/2010 6:41:45 AM(UTC)
Maytag Performa Washer makes loud noise (Washer Repair)
by gsgray2806 12/31/2009 4:49:46 PM(UTC)
Maytag performa washer (Washer Repair)
by semerm12 10/22/2009 2:50:40 PM(UTC)
