jtmitche
#1 Posted : Tuesday, February 5, 2008 6:31:26 AM(UTC)
jtmitche
When I try to replace my water filter with either a new filter, the old filter or bypass plug...... water leaks around the filter. O-rings seems ok. What could cause leak? I replaced water valve with another one which I think was good but still leaks at water filter
meganet3
#2 Posted : Saturday, March 8, 2008 11:11:50 PM(UTC)
meganet3
Hi, did you ever resolve the water filter leak issue? I just changed mine and I have the same problem as you.
jtmitche
#3 Posted : Sunday, March 9, 2008 10:06:49 AM(UTC)
jtmitche
Yes, I resolved. When filter was out you can see that the part it screws into has cracked. To prove it, take filter out plug hole and hit water dispenser and you can see it leak where the crack is.
I bought that part and replaced it myself. Quite easy to do and part is around $50.
Frigidaire water filter leak (Refrigerator & Freezer Repair)
by grijalva006 2/13/2011 5:42:26 PM(UTC)
coils feezing up and water filter leaking out water (Refrigerator & Freezer Repair)
by beth hatcliff 2/13/2010 8:44:19 AM(UTC)
water filter leaking on Kitchenaid side by side (Refrigerator & Freezer Repair)
by DavidDouglas 10/8/2009 7:22:40 AM(UTC)
Water filter leak (Refrigerator & Freezer Repair)
by leakyblog 7/14/2009 1:31:49 PM(UTC)
