red arrow 57
#1 Posted : 15 years ago
red arrow 57
my freezer is not defrosting. I checked the defrost timer by turning it and it goes thru cycle, it
sounds like a clock ticking.
#2 Posted : 15 years ago
my freezer is not defrosting. I checked the defrost timer by turning it and it goes thru cycle, it sounds like a clock ticking.
The timer could be ticking but not moving the cam.
You have to mark a spot on the frame/cover and on the cam, then check it an hour or so later to see if it is rotating. Note that the timer cam may hang up at some other point in it's rotation.
Rotate the timer cam till the compressor and the fans go off.
You are now in a defrost cycle.
Check if the defrost element comes on.
Be careful you do not want to burn your fingers.
If it does heat up then probably your timer is toast.
If not the problem could be the defrost element or defrost thermostat.
Could also be the timer perhaps it's internal contacts are shot.
Following are a couple good sites with basic fridge repair help on checking the above components.
http://www.applianceaid.com/refrigerator.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Whirlpool Defrost not working and freezer and fridge warming up (Refrigerator & Freezer Repair)
by kimberdesi 8 years ago
Defrost not working (Refrigerator & Freezer Repair)
by wagnerlip 8 years ago
by smokyjoeko 10 years ago
defrost not working (Refrigerator & Freezer Repair)
by carlosl. 12 years ago
GSS201EMDWW Defrost not working, again. (Refrigerator & Freezer Repair)
by Davdc5 13 years ago
by swallman 13 years ago
Adaptive Defrost not working (Refrigerator & Freezer Repair)
by radair 14 years ago
Kitchenaid refrig: defrost not working leading to icy refrigerator (Refrigerator & Freezer Repair)
by osbock 14 years ago
GE refrig defrost not working (Refrigerator & Freezer Repair)
by beachval 15 years ago
by smodellb 15 years ago
Defrost not working? (Refrigerator & Freezer Repair)
by jfuqua1966 15 years ago
Samsung Refrigerator Defrost Not Working (Refrigerator & Freezer Repair)
by eckerj 16 years ago
Defrost Not Working Properly (Refrigerator & Freezer Repair)
by machengo82 16 years ago
Auto defrost not working (Refrigerator & Freezer Repair)
by kimseyray 16 years ago
Defrost not working after all new parts (Refrigerator & Freezer Repair)
by tradencookies 16 years ago
