adepinto
#1 Posted : Friday, February 1, 2008 7:46:32 PM(UTC)
adepinto
I could use a little help. My oven lights after a very long time - sometimes 30 minutes. From what I understand, My ignitghter is working, because I can see it glowing(fairly brightly), but I never tested it with a volt meter. All the burners on top work with out any problems. When the oven is not lighting, I do not hear or smell any gas. I am assuming that my problem is a faulty safety valve not letting the gas thru. Although, every once in a while the oven works fine without any problems. I don't think it's a thermostat or a contronl panel problem,( because once light the oven works ok) but I could be wrong. Does this problem sound like a faulty safety valve?, and is a faulty safety valve a common problem? Thank you.
Anthony
misterfixall
#2 Posted : Saturday, February 2, 2008 2:35:20 PM(UTC)
misterfixall
try replacing ignitor
fyxer
#3 Posted : Saturday, February 2, 2008 3:37:26 PM(UTC)
fyxer
Safety valves do go bad sometimes but not often,for example in the last five years i have change maybe two safety valves,this condition you have sound like a ignitor going bad, taking a long time to light is common when ignitor's are weak.
adepinto
#4 Posted : Saturday, February 2, 2008 6:08:47 PM(UTC)
adepinto
Thank you.
Gas safety valve - "manual lockout"? (Oven Repair (including Ranges and Cooktops))
by joea99 8/10/2022 3:50:56 PM(UTC)
Oven gas control/safety valve (Oven Repair (including Ranges and Cooktops))
by Michael47 12/5/2020 9:02:49 PM(UTC)
New ignitor draws too much current; will it cause the Safety Valve to not open? (Oven Repair (including Ranges and Cooktops))
by yoyopol2000 8/28/2013 4:58:19 AM(UTC)
Dual Safety Valve Problems (Oven Repair (including Ranges and Cooktops))
by tanders1 7/23/2013 6:25:29 AM(UTC)
Maytag oven slow to light, have replaced igniter and safety valve (Oven Repair (including Ranges and Cooktops))
by kellih 1/23/2013 4:30:54 PM(UTC)
Ignitor/Safety valve problem?? (Oven Repair (including Ranges and Cooktops))
by HkyFrk 11/26/2012 7:37:58 AM(UTC)
new safety valve (Oven Repair (including Ranges and Cooktops))
by smitty11 2/18/2012 3:20:54 PM(UTC)
GE XL44 Safety Valve Assembly Replacement AP2022751/WB19K12 (Oven Repair (including Ranges and Cooktops))
by stefantomoiu 12/13/2010 9:36:04 AM(UTC)
Igniter lights , replaced gas safety valve and over still wont light until you hit th (Oven Repair (including Ranges and Cooktops))
by bigdaddywyatt 12/8/2010 6:32:42 AM(UTC)
Safety valve (Oven Repair (including Ranges and Cooktops))
by philetus 7/19/2010 5:41:58 PM(UTC)
New safety valve large flames in oven (Oven Repair (including Ranges and Cooktops))
by minuteman 1/22/2010 2:10:19 PM(UTC)
Oven safety valve (Oven Repair (including Ranges and Cooktops))
by WALJ 6/21/2009 2:45:59 PM(UTC)
Safety Valve Problem ? (Oven Repair (including Ranges and Cooktops))
by rashaw 4/27/2009 6:50:54 PM(UTC)
GE XL44 Ignitor / burner / safety valve replacement (Oven Repair (including Ranges and Cooktops))
by bhaughee 4/22/2009 3:12:12 AM(UTC)
Help...A Gaffers & Sattler Oven Safety Valve is desperately needed. (Oven Repair (including Ranges and Cooktops))
by AdrienneInNY 11/13/2008 7:41:56 PM(UTC)
