Hi there! The washing machine does not pump the water out. Previously I had the entire draining coming from upstairs plugged with fiberglass fibers by some idiot.. I forced the water with the water hose from the roof , under pressure and I guess before the system got unplugged some fiber glass and dirty water went thru the evacuation hose from the washing machine, inside the washing machine. I found about a fist full of fine fiberglass on the bottom of the drum. Also I run the washing machine after I cleaned it out ,and it drained OK, Now it did not drain. What could be plugged? The water pump? or there is a filter like a sieve somewhere that got plugged up?
Rank: Administration
Groups: Administrators
The model number is incomplete but I will provide a link to give you a view of a similiar washer. Click: Model WCCD2050Y0WC Please get the complete model and serial numbers before ordering parts. First make sure you have the drain professionally cleaned. As for the washer open it up and remove the hoses and make sure they are clean and clear. Make sure there is no material left in the tub, also make sure the material didnt come from the washer (tub damage). When you get to the pump make sure you pull it out and clean the housing where the hoses attach, also get a flashlight and make sure the impeller in the housing is not damaged or wound up with fibers. Once everything is sparkly clean put it back together and test it. If it doesnt drain, check to see if the pump is getting proper voltage if it is and the pump still won't work then the pump is probably bad. Here is the information on the pump used on that series: Part Details - GEH Pump and motor assembly, part number: AP3160348
Thanks Matt! Problem solved! It took me a while to figure how to open the damn thing, with that fake lock in the front, and no screws to remove the front cover... I pushed my screwdriver in between pannels, and it opened! The water pump had fibers at the exit chamber. Cleaned it out and everything is basck to normal. Thanks again, Paul
I faced the same problem with my washing machine. washing machine faulty switches problem is very critical problem.Sometimes overheating issue also occurred and I have been searching for the best washing machine repair dubai service center. Because all problems would be solve through expert technicians.
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
So it might not that how the washing machine works like it intake the water automatically and also drain out the water by the horse pipe so some times the horse pipe jammed or locked so if that happened one must call the washing machine repair for fixing the issue.
Hi there , yes washing machine repair can be a tedious job but we are local repair service so we can help you out since washing machine repair requires a skilled technician you can get help from us . Check out our blog to learn more about washing machine repair. Repair Thankyou .
Rank: Guest
Groups: Guests
If you need any help with the repair of home appliances whether its small or large visit us for free quote .
Rank: Guest
Groups: Guests
There are many different options for where to get money for different things. For example, you can buy things with cash, credit, or a mortgage https://manchestermortgages.co.uk/. Each option has its own pros and cons.Cash is the simplest option. You just need to have the money upfront. However, it can be difficult to save up enough cash for larger purchases.Credit gives you more flexibility in terms of timing, but you will need to pay interest on the loan.A mortgage is a long-term loan that can be used to purchase big-ticket items like a house or a car. However, you will need to make monthly payments over the life of the loan.
Help with washing machine! Model GTW460ASJ7WW
My washing started out with not agitating but now after changing out some parts it now will not spin. It would fill, drain and spin as normal at at the beginning and just would not agitate on any cycle. So I first replaced the base of the agitator- that was not the issue (will still work normally but no agitating). Next I replaced the mode shifter and clutch and since doing this it now will not spin (which it did before) and still does not agitate. I have no idea what to check next! I am at wits end with this thing!
