mimiki
#1 Posted : Wednesday, January 30, 2008 3:58:29 PM(UTC)
mimiki
my dryer stop heating and i check it it was the heating fuse was open , so i replace it but when i open the heating element was grounded i replace it to and the hi limit came with it as well i replace it , it worked for like a i month and today stop heating opened and the heating fuse was blown again , what you think could be the problem with it? before i go foward please help.
#2 Posted : Thursday, January 31, 2008 1:01:38 PM(UTC)
Most likely the dryer was overheated due to clogged exhaust and insufficient air flow.
mimiki
#3 Posted : Thursday, January 31, 2008 3:53:52 PM(UTC)
mimiki
but that's weird cause i checked the duct and everything was clear no lint blockeage
#4 Posted : Thursday, January 31, 2008 5:15:06 PM(UTC)
Did you check the blower and the air ducts inside the dryer?
Ted Rzewucki
#5 Posted : Friday, February 1, 2008 8:25:52 AM(UTC)
Ted Rzewucki
Kindly send me your e-mail if any and I will send you my problems with kenmore dryer
Thank you
Please reply
#6 Posted : Friday, February 1, 2008 8:31:14 AM(UTC)
Hi Ted,
Post your e-mail, please.
Ted Rzewucki
#7 Posted : Friday, February 1, 2008 8:40:26 AM(UTC)
Ted Rzewucki
Hi Ted,
My KENMORE DRYER STARS AN THAN SHUT OFF.Why?
Model #C110-8170092 ove 35 year old
mimiki
#8 Posted : Friday, February 1, 2008 4:15:14 PM(UTC)
mimiki
yes i checked both blower and ducts was clean and clear.
abbie
#9 Posted : Friday, February 1, 2008 4:29:08 PM(UTC)
abbie
If your talking about the fuse in the electrical box,and if you are using two 30 amp fuses in this box,then the trouble is in the electrical box itself. More then likely there is heat building up in the fuse holders causing the fuse to blow.So if you change this box it will solve your problem
mimiki
#10 Posted : Friday, February 1, 2008 4:41:06 PM(UTC)
mimiki
no the fuse i mentioned was not the panel ,it was the dryer heater fuse
Guest (7)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
GE dryer problems (Dryer Repair)
by js072384 5/12/2012 9:15:49 PM(UTC)
Dryer Problems (Dryer Repair)
by smartin349 1/1/2012 6:35:54 AM(UTC)
by Mickey_951 10/1/2011 5:53:04 PM(UTC)
by Tsailor 3/4/2011 3:51:27 PM(UTC)
Dryer problems (Dryer Repair)
by Shoopes 11/16/2009 5:24:35 PM(UTC)
by talbot 11/2/2009 9:37:55 AM(UTC)
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 10/19/2009 11:05:38 AM(UTC)
Dryer problems mikeo (Dryer Repair)
by mikeo1899 8/4/2009 9:15:16 AM(UTC)
by berniefl 7/24/2009 6:13:21 AM(UTC)
Dryer problems HELP (Dryer Repair)
by MizzJessica 7/6/2009 10:39:42 PM(UTC)
by mbgrdido 3/24/2009 7:52:23 PM(UTC)
by janezucker 12/29/2008 9:36:33 AM(UTC)
Roper Dryer problems (Dryer Repair)
by b0001744 8/29/2008 9:38:02 AM(UTC)
