Barbgrady
#1 Posted : Sunday, October 4, 2009 7:14:11 AM(UTC)
Barbgrady
Do i need a heating element or is there another problem?
ApplianceJunk
#2 Posted : Sunday, October 4, 2009 8:02:23 AM(UTC)
ApplianceJunk
There are a few things that can make your dryer not heat.
Voltage to the dryer (240v) if electric.
Heating element.
Thermo fuse.
SublimeMasterJW
#3 Posted : Sunday, October 4, 2009 9:21:17 AM(UTC)
SublimeMasterJW
To get to the heating element on most of these dryers you remove the back dust cover:
UserPostedImage
1. Hi Limit (small limit upper right hand side of this pic)
the most frequent problem if dryer RUNS but no heat.
2. Heater assembly. 7. Control thermostat(s).
If all of those items turn out to have continuity, you may have a bad timer.
Here is a burnt contact: UserPostedImage
or a bad breaker as AJ says. :D
UserPostedImage
#4 Posted : Sunday, October 4, 2009 9:34:07 AM(UTC)
Replacement parts for WHIRLPOOL REX5634PQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208528187.pdf
If you put the unit into timed dry and the timer advances you should have 240 volts as the timer on this unit uses 240 volts.
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
LG dryer not drying clothes (Dryer Repair)
by DGRA0005 7/6/2020 5:42:51 PM(UTC)
Whirlpool wed4800bq1 dryer not drying very good (Dryer Repair)
by t3i 3/19/2019 3:10:19 PM(UTC)
Dryer not drying (Dryer Repair)
by Scotty dog 12/3/2017 10:46:30 AM(UTC)
Dryer not Drying Clothes (Dryer Repair)
by Epfever1 12/1/2017 9:44:44 AM(UTC)
dryer not drying and water in drum (Dryer Repair)
by sonjawainwright 8/23/2017 8:07:12 AM(UTC)
Matag Dryer not drying in Intellidry Mode (Dryer Repair)
by themooser98 8/23/2017 5:43:28 AM(UTC)
maytag centennial electric dryer not drying/heating anymore (Dryer Repair)
by lloyd raymond martin 6/7/2017 5:34:16 PM(UTC)
Maytag Centennial Dryer not drying completely. (Dryer Repair)
by bryanakers 10/10/2016 5:42:01 AM(UTC)
My Dryer not drying (Dryer Repair)
by anikabrown 3/29/2016 3:57:03 AM(UTC)
Dryer not Drying (Dryer Repair)
by BraxLimbo 11/12/2015 11:08:58 PM(UTC)
Roper Dryer not drying (Dryer Repair)
by fhorta 11/3/2015 5:28:30 AM(UTC)
Samsung dryer not drying/get hot (Dryer Repair)
by Mommydearest819 5/30/2015 3:31:39 AM(UTC)
LG Tromm Dryer not drying (Dryer Repair)
by earcaesar 3/26/2015 5:50:26 PM(UTC)
