Hi Guys I am laid off and need to fix my own dryer I am just a girl - but I know I can do it I have several pairs of baseball and football pants that need drying
The dryer won't heat any more What should I check first Thanks
Linda
The first thing that always should be checked before you start suspecting any parts on the dryer is the source voltage where the cord hooks up to the back of the unit. But before doing any of this the question needs to be asked, have you ever done any sort of electrical testing before?
The cord is secure. What should I check next. Linda
Originally Posted by: lemme  The cord is secure. What should I check next. Linda That's great, but it has to be established whether or not it's actually receiving correct AC voltage. A Volt meter needs to be used to verify if 240 volts is present at the two outside leads where the cord attaches to the dryer.
