yogigrogi
#1 Posted : 17 years ago
yogigrogi
error code F0 appears about 2 hours after the oven has been used. Hit the clear button and it goes away. A while later it comes back........Code says to replace the control panel??? Help..
#2 Posted : 17 years ago
Turn the power off.
Open the control panel and remove the control panel ribbon from the control board.
Restore the power and monitor the oven for a day.
If the error code shown up again, replace the control board.
If the error code disappeared, replace the control panel.
- The part number for the control board (ERC) is AP3203778
- The part number for the control panel is AP3205594
yogigrogi
#3 Posted : 17 years ago
yogigrogi
Question? Is the ribbon cable supposed to have a connector at the end of it? It appears that the ribbon end is inserted in the connector on the control board and is held in by a plastic clip..?? thanks.. Want to make sure I did not damage the ribbon cable.
#4 Posted : 17 years ago
Originally Posted by: yogigrogi Go to Quoted Post
Question? ... It appears that the ribbon end is inserted in the connector on the control board and is held in by a plastic clip..?? ...
Yes. This is the way how it was designed.
yogigrogi
#5 Posted : 17 years ago
yogigrogi
I did remove the ribbon cable, power back on and within 5 min. error code came back on. Looks like i will order a new control erc. thanks for the help......
#6 Posted : 17 years ago
Keep me updated, please.
yogigrogi
#7 Posted : 17 years ago
yogigrogi
Ordered a CRC part #AP3203778. Installed it and nothing happened!!!! No clock etc.. Called Appliance Parts Pros, and they sent another CRC.. Installed it and clock worked, however after using the oven once back to the same old story!!!! Error code F0...? Ccccccccccould it be another bad ERC? Any suggestions??? thanks .
pat
#8 Posted : 17 years ago
Hi Pat,
In such situation I would recommend to call the APP customer service to exchange the defective ERC one more time and replace the control panel together with the new ERC.
Error Code F05 (Washer Repair)
by RBanz 10 years ago
error code f09&tripping circuit breaker (Washer Repair)
by yirga29 14 years ago
error code F02 (Washer Repair)
by javelin72 14 years ago
error code f06 (Dryer Repair)
by ahdrywall74131@yahoo.com 15 years ago
What does the error code F06 mean? (Washer Repair)
by douggray 15 years ago
Whirlpool Duet error code F06 (Washer Repair)
by rhamiltonnc 15 years ago
Amana oven error code F0 (Oven Repair (including Ranges and Cooktops))
by tlove61 16 years ago
Error Code F0 for GE Oven? (Oven Repair (including Ranges and Cooktops))
by andrewq 16 years ago
Front Load Maytag What is Error Code f06 (Washer Repair)
by mbippus 17 years ago
