yogigrogi
#1 Posted : Monday, January 28, 2008 3:12:06 PM(UTC)
yogigrogi
error code F0 appears about 2 hours after the oven has been used. Hit the clear button and it goes away. A while later it comes back........Code says to replace the control panel??? Help..
#2 Posted : Monday, January 28, 2008 6:26:01 PM(UTC)
Turn the power off.
Open the control panel and remove the control panel ribbon from the control board.
Restore the power and monitor the oven for a day.
If the error code shown up again, replace the control board.
If the error code disappeared, replace the control panel.
- The part number for the control board (ERC) is AP3203778
- The part number for the control panel is AP3205594
yogigrogi
#3 Posted : Monday, January 28, 2008 7:21:51 PM(UTC)
yogigrogi
Question? Is the ribbon cable supposed to have a connector at the end of it? It appears that the ribbon end is inserted in the connector on the control board and is held in by a plastic clip..?? thanks.. Want to make sure I did not damage the ribbon cable.
#4 Posted : Monday, January 28, 2008 7:40:25 PM(UTC)
Originally Posted by: yogigrogi Go to Quoted Post
Question? ... It appears that the ribbon end is inserted in the connector on the control board and is held in by a plastic clip..?? ...
Yes. This is the way how it was designed.
yogigrogi
#5 Posted : Monday, January 28, 2008 7:46:04 PM(UTC)
yogigrogi
I did remove the ribbon cable, power back on and within 5 min. error code came back on. Looks like i will order a new control erc. thanks for the help......
#6 Posted : Monday, January 28, 2008 7:52:19 PM(UTC)
Keep me updated, please.
yogigrogi
#7 Posted : Saturday, March 15, 2008 2:38:49 PM(UTC)
yogigrogi
Ordered a CRC part #AP3203778. Installed it and nothing happened!!!! No clock etc.. Called Appliance Parts Pros, and they sent another CRC.. Installed it and clock worked, however after using the oven once back to the same old story!!!! Error code F0...? Ccccccccccould it be another bad ERC? Any suggestions??? thanks .
pat
#8 Posted : Tuesday, March 18, 2008 12:31:24 PM(UTC)
Hi Pat,
In such situation I would recommend to call the APP customer service to exchange the defective ERC one more time and replace the control panel together with the new ERC.
Error Code F05 (Washer Repair)
by RBanz 9/14/2015 1:51:50 PM(UTC)
error code f09&tripping circuit breaker (Washer Repair)
by yirga29 2/8/2011 1:01:03 PM(UTC)
error code F02 (Washer Repair)
by javelin72 2/2/2011 2:50:23 PM(UTC)
error code f06 (Dryer Repair)
by ahdrywall74131@yahoo.com 9/13/2010 4:35:39 PM(UTC)
What does the error code F06 mean? (Washer Repair)
by douggray 9/9/2010 5:31:59 PM(UTC)
Whirlpool Duet error code F06 (Washer Repair)
by rhamiltonnc 10/19/2009 7:31:58 PM(UTC)
Amana oven error code F0 (Oven Repair (including Ranges and Cooktops))
by tlove61 9/22/2009 8:14:18 AM(UTC)
Error Code F0 for GE Oven? (Oven Repair (including Ranges and Cooktops))
by andrewq 1/17/2009 4:42:46 PM(UTC)
Front Load Maytag What is Error Code f06 (Washer Repair)
by mbippus 8/28/2008 12:59:52 PM(UTC)
