vfourider
#1 Posted : Friday, January 18, 2008 8:54:30 AM(UTC)
vfourider
I received an error code on my electric oven of F3E2. Based on some blogs and speaking with a representative at Whirlpool, I was told I would need to replace my control panel part # 6610454 which I did. The oven still does not work properly. Both the broiler and the lower heating elements light and it is not maintaining the proper temperature (way too hot). Is it possible I replaced the wrong part or received a new faulty part? What else would I need to replace?
Please help.
Vince
vfourider
#2 Posted : Monday, January 28, 2008 5:53:35 PM(UTC)
vfourider
I see a lot of views on my issue, but no suggestions. Can any of you techs out there offer a remedy? I spoke with two different techs and reviewed whirlpools factory specs/repair manual and all state to check the oven temperature sensor with an ohm meter which should state at or near 1100 ohms. If the sensor, the connectors and the wire harness to the sensor are OK, the issue is with the control board which I replaced and still the oven overheats and does not maintain the proper temperature. Come on you appliance pros, write me back with a suggestion.........
Whirlpool Control Panel VOM Testing (Washer Repair)
by Guest 10/19/2023 10:23:21 AM(UTC)
Whirlpool Control Panel Replacement Help (Oven Repair (including Ranges and Cooktops))
by Argo 11/8/2018 7:14:17 AM(UTC)
whirlpool control panel switch lighting not working (Refrigerator & Freezer Repair)
by orionengnr 12/30/2016 9:31:49 AM(UTC)
line voltage in old Whirlpool control panel? (Dishwasher Repair)
by Paul_illinois 2/19/2014 7:40:06 AM(UTC)
whirlpool control panel (Oven Repair (including Ranges and Cooktops))
by jcdamante 3/14/2013 3:16:13 PM(UTC)
how to remove a Whirlpool control panel (Oven Repair (including Ranges and Cooktops))
by andrew_80921 10/5/2012 2:17:23 PM(UTC)
Whirlpool Control Panel (Oven Repair (including Ranges and Cooktops))
by gshiple 12/11/2011 12:10:09 PM(UTC)
Whirlpool Control Panel malfuntion (Dishwasher Repair)
by k2hockey 12/13/2010 6:51:32 AM(UTC)
whirlpool CONTROL PANEL BROKE (Oven Repair (including Ranges and Cooktops))
by lacosta75 6/11/2010 7:38:41 AM(UTC)
replacing whirlpool control panel cover (Dishwasher Repair)
by cwl1985 5/13/2010 7:59:37 AM(UTC)
by jd76 2/24/2010 1:54:35 PM(UTC)
Whirlpool Control Panel Issue? (Dishwasher Repair)
by bermanbj 8/26/2009 7:47:28 AM(UTC)
