vikingboy
#1 Posted : Friday, September 25, 2009 1:04:15 PM(UTC)
vikingboy
My dryer will not produce heat. The voltage at the plug is 240VAC. I have checked for continuity of the heating element, the thermal cutoff, and the thermal fuse. All are closed. There is no voltage at the heating element leads. I have pulled the thermistor and found that it is open at room temperature and when I heat it up with a hair dryer. I tried shorting out the thermistor leads, but the element still does not heat up. Went to Sears and checked out the continuity of a new thermistor and it also was open at room temp. Any ideas of what I'm missing?:confused:
#2 Posted : Friday, September 25, 2009 6:15:43 PM(UTC)
The model number you posted does not come up. Verify and repost it.
vikingboy
#3 Posted : Sunday, September 27, 2009 4:14:42 AM(UTC)
vikingboy
Sorry, the model number is 11063932101. I replaced the thermostat and all is well. The old one had continuity, but after shorting the wires out, the elements came on, so I knew I had it. Thanks for offering to help.
#4 Posted : Sunday, September 27, 2009 1:00:49 PM(UTC)
You are welcome. I'm glad to hear you were able to fix it.
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
Kenmore dryer will not heat (Dryer Repair)
by cfalter 9/29/2012 4:34:50 PM(UTC)
Kenmore dryer will not heat on second cycle (Dryer Repair)
by Jim G42 7/15/2012 12:18:17 PM(UTC)
Kenmore Dryer Will not heat (Dryer Repair)
by ajb1010 5/21/2012 2:36:03 PM(UTC)
by saw3c 5/18/2010 9:48:06 AM(UTC)
Kenmore Dryer Will Not Heat Up (Dryer Repair)
by mastaone 11/8/2009 12:44:09 PM(UTC)
Kenmore dryer will not heat.3 weeks-- my wife is mad (Dryer Repair)
by topagent 7/31/2009 12:51:43 PM(UTC)
by lpennock 5/10/2009 3:56:08 PM(UTC)
Kenmore Dryer will not heat (Dryer Repair)
by T.A.M. 2/9/2009 5:29:54 PM(UTC)
