I have a whirlpool gas built in wall oven/broiler,igniter will not spark dued to no power to the igniter assy.Checked fuse in electric panel and ran a continuity checked ok,what else should I check? correct model # sb130per3
Originally Posted by: jlipinski2003 I have a whirlpool gas built in wall oven/broiler,igniter will not spark dued to no power to the igniter assy.Checked fuse in electric panel and ran a continuity checked ok,what else should I check? correct model # sb130per3 it,pays to have a guide or operating manuel when purchaseing a used appliance other wise a wrong setting or settings will cause the appliance not to work at all. IT was A wrong operating setting THAT caused problems like no power to igniter.Found out on my own.sure will check information on operating features in the future lesson well learned.
