dstout8267
#1 Posted : Tuesday, September 22, 2009 8:37:07 AM(UTC)
dstout8267
Timer Sticks In Normal Cycle, Runs Forever, Had Service Out, Needs
New Timer, Part Ap4043083, Ordered It, Need Install Instructions,
Looks Easy But Do You Have Any Help?
#2 Posted : Wednesday, September 23, 2009 8:47:23 AM(UTC)
Do not rush with the timer.
One of the most common cause for such problem is an obstructed air flow. The first thing I would do is clean the vent all the way from the dryer back panel through the vent outlet. Make sure the outlet flopper is opening properly. Take the dryer apart. Check the blower wheel and clean all air ducts inside.
If there is nothing wrong then replace the high limit thermostat (#17 on the diagram) and the cycling thermostat (#8 on the diagram).
Here is the Service manual.
- The high limit thermostat Part number: AP4036956
- The cycling thermostat Part number: AP4037199
dstout8267
#3 Posted : Wednesday, September 23, 2009 10:03:15 AM(UTC)
dstout8267
Burner does not come on all the time either, runs for about 10-15 sec and skips times that ignitor comes on some times, several times ignitor lights
but flame does not happen. Ran it on timed cycle which appears to advance,
normal cycle does not. I did replace high temp limit above burner #17 on
drawings. Again have maytag. Hoping its not the coils of the burner. Timer
still does not advance on normal dry cycle. Air is flowing well outside at vent. had a service guy out but he really did nothing for $40. Suppose I'll call another one.
#4 Posted : Saturday, September 26, 2009 3:06:59 PM(UTC)
Sorry for the delay.
Quote:
...Burner does not come on all the time either, runs for about 10-15 sec and skips times that ignitor comes on some times, several times ignitor lights
normal cycle does not...
Very likely the problem is a bad gas valve coils.
- The coil kit Part number: AP3094251
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
Whirlpool ler5635lq0 timer issue (Dryer Repair)
by Rolandtd 3/26/2024 6:15:44 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Hotpoint timer stalls in middle of opperation (Dishwasher Repair)
by Fidofax 2/15/2024 8:50:49 AM(UTC)
Dryer won’t stop after timer ends (Dryer Repair)
by ittssarah 2/4/2024 9:04:33 PM(UTC)
Kenmore 592-89032 Dryer POWERS OFF mid-cycle on both timer and moisture settings (Dryer Repair)
by Guest 7/15/2023 6:11:04 AM(UTC)
Alternate timer control for older Maytag top load washer ModelLAT8210AAW (Washer Repair)
by Guest 7/7/2023 12:43:57 PM(UTC)
Is the timer bad? (Dryer Repair)
by FatnSlo 5/1/2023 1:35:57 PM(UTC)
Dryer Timer Humming (Dryer Repair)
by terzolino 4/6/2023 10:18:16 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
GE Profile Range Timer Button Not Working (Oven Repair (including Ranges and Cooktops))
by Bush444 11/23/2022 10:11:35 AM(UTC)
PAVT910AWW Maytag no spin (agitates instead), no refill, no rinse, timer stops. (Washer Repair)
by owkaye 7/27/2022 5:04:45 AM(UTC)
Older Maytag top load “timer” (Washer Repair)
by CP1 6/4/2022 3:58:19 PM(UTC)
