backyardmechanic
#1 Posted : Monday, September 21, 2009 5:35:48 PM(UTC)
backyardmechanic
I have this GE side by side refrig. It was leaking water out of the front, in front of the freezer side. Checked the door it was closed, on this inside it was defrosted and the food was defrosting. The fan in the back is running and the fan in the back next to the compressor is running. I can hear a "clicking " noise coming from the mother board when I hold the door swith in the close position and turn the freezer control knob from 0 to 1. Both of the fans come on, however the compressor doesn't engage and run. I was hoping for some advice on what to trouble shoot and to maybe find a online manual for this, anything would be great, thanks.
#2 Posted : Tuesday, September 22, 2009 2:40:18 AM(UTC)
Remove the motherboard cover in the back of fridg and locate the 3 pin power connector. Notice whic pins are labled, Line and Comp. Put a jumper between thes mating pins on the connector. Plug in fridg. compressor should run, if so, replace the motherboard. AP4436216
backyardmechanic
#3 Posted : Tuesday, September 22, 2009 4:39:24 PM(UTC)
backyardmechanic
the compressor did come on with your recomendations thanks will look for a mother board
30+ Yr. Old GE Washer- Need Advice (Washer Repair)
by Not_Handy 7/24/2016 3:05:59 PM(UTC)
Kenmore Washer --- stumped... NEED ADVICE! (Washer Repair)
by rlhfixit 6/5/2015 12:37:35 PM(UTC)
Relay Burnt Out. Need Advice (Dryer Repair)
by Schradermt 2/27/2015 7:43:40 AM(UTC)
Whirlpool Side By Side Cooling Issues Need Advice....... (Refrigerator & Freezer Repair)
by CaptainWarmFridge 6/22/2014 1:58:09 PM(UTC)
please need advice (Dryer Repair)
Belarus mikegurley81 12/1/2013 8:20:09 AM(UTC)
Leaking washer need advice (Washer Repair)
by GE Nightmare 10/5/2013 1:54:30 PM(UTC)
Need Advice!!!!!! (Refrigerator & Freezer Repair)
by piscesbound 2/8/2013 12:32:56 PM(UTC)
by csinshaw 12/17/2012 5:57:55 PM(UTC)
Need advice on Kenmore upright freezer (Refrigerator & Freezer Repair)
by rgraff 12/13/2012 6:18:44 PM(UTC)
Washer won't agitate, spin or drain - need advice! (Washer Repair)
by BlueSapphire 8/7/2012 7:52:27 AM(UTC)
Need advice on a Whirlpool (Dryer Repair)
by mclldavidson 3/29/2012 1:29:44 PM(UTC)
Freezer on top model- Evap not getting cold - need advice (Refrigerator & Freezer Repair)
by WI-landlord 3/7/2012 10:08:38 AM(UTC)
Need advice on what to check: dryer not drying (Dryer Repair)
by antessima 12/1/2011 5:14:45 PM(UTC)
fixing fridge, need advice (Refrigerator & Freezer Repair)
by Big Bigby 9/2/2011 2:20:55 AM(UTC)
Need Advice: Is the tech correct? (Refrigerator & Freezer Repair)
by mealto 5/4/2011 7:56:39 AM(UTC)
