yumickapowell
#1 Posted : Saturday, September 19, 2009 10:22:04 AM(UTC)
yumickapowell
I have Maytag Performa Dryer and it initially was making a squeaking noise while drying the clothes but then it stopped. So now it makes humming sound but the drum wont turn. Is it the belt?
#2 Posted : Sunday, September 20, 2009 2:29:02 AM(UTC)
Here are your parts includes the wiring diagram.
Replacement parts for MAYTAG PDET910AYW | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16026315.pdf
Is it the belt?
Could be but also could be that the drum is jammed or the motor is toast.
Try turning the drum by hand should turn fairly easily.
If the motor is shot/jammed it is usually more of a buzz than a hum.
Open it up and take a look.
Whenever you work on a dryer it is a good idea to give the interior a good cleaning, also clean/check your vent system.
LG Dryer wont turn off - DLGX8101V (Dryer Repair)
by cameroninoc 2/3/2023 1:22:44 PM(UTC)
LG Dryer wont turn on (Dryer Repair)
by stz2 7/28/2021 2:09:54 AM(UTC)
Kenmore Dryer Wont Turn On (Dryer Repair)
by tmurphy12 11/11/2017 5:37:21 PM(UTC)
Dryer wont turn (Dryer Repair)
by tishondaw0104 11/16/2013 6:32:09 PM(UTC)
Dryer wont turn on. Nothing at all (Dryer Repair)
by jim5775 2/7/2013 1:31:10 PM(UTC)
Dryer wont turn on, bulb stays on when door closed (Dryer Repair)
by mazw 7/24/2012 4:21:01 PM(UTC)
Dryer wont turn on, bulb stays lit when door closed (Dryer Repair)
by mazw 7/24/2012 4:13:34 PM(UTC)
by sweetness 6/21/2012 12:24:11 PM(UTC)
admiral dryer wont turn on (Dryer Repair)
by tammy27 6/12/2012 1:08:36 PM(UTC)
by G.A.Russell 2/12/2012 12:42:26 PM(UTC)
by blackcobra427 11/2/2011 9:31:12 AM(UTC)
Roper Dryer wont turn on (Dryer Repair)
by edwardsnl 1/15/2011 12:37:58 PM(UTC)
by snooki 12/2/2010 5:45:01 PM(UTC)
dryer wont turn off when on timed load (Dryer Repair)
by michaelsneri 7/28/2010 3:24:04 PM(UTC)
by ritadi 7/4/2010 9:30:53 AM(UTC)
