nairobi
#1 Posted : Wednesday, September 16, 2009 2:02:01 PM(UTC)
nairobi
Dryer belt is almost new. The dryer started to make loud scratching sounds and then stopped. When trying to start would only make a loud buzzing sound. I replaced the felt front seal. The old one was in horrible condition. I had the belt replaced professionally, but not the felt . The buzzing sound was still present. Spun the drum several times and the dryer then started and ran. However, when stopped , it would not restart, and the buzzing sound came back. Second attempt to spin the drum result in a start, but when stopped, would not restart and NOW no buzzing sound either. Main fuse at fus box was checked. I am back. For the heck of it about an hour later I pressed the start switch and the dryer began running. I decided to let if run. It ran four about 15 min and then stopped. When I attempted to restart, I got the same buzz sound. It acts like something is sticking. The drum wants to spin but it catches and stops.
#2 Posted : Thursday, September 17, 2009 4:05:54 AM(UTC)
Sounds like you may still have a drum that is putting too much load on the motor. This is causing the motor to overheat, it's internal thermal cutoff trips and you cannot restart is till the thermal cutoff resets.
Try rotating the drum by hand. It should rotate fairly easily. Try this on a couple other dries so you get a feel for what it should feel like.
If drum rotates OK then you probably need a new motor.
nairobi
#3 Posted : Thursday, September 17, 2009 8:20:54 AM(UTC)
nairobi
I did attempt to rotate the drum by hand. It does NOT rotate easliy. While I can get it to rotate it takes an effort to push it around. I have found that if I keep the swithch pushed in and reach up to the start button, I can sometimes get the drum to tumble and begin to work while forcing the drum around but it is not sustainable after a few minutes. Is the motor still the problem?
#4 Posted : Thursday, September 17, 2009 8:48:04 AM(UTC)
Probably but only if the drum is rotating OK so you still have to try rotating on a couple other units.
nairobi
#5 Posted : Friday, September 18, 2009 8:14:08 AM(UTC)
nairobi
Okay. I can start the dryer in its 3 catagories of Regular Dry, Permanent Press and just Plain Air Dry. Basicilly the same thing happens, it runs but then stops. Dryer is hard to turn in any of the settings by hand. Could it be possible that I may have not reinstalled the drum correctly and that is causing the binding? However I will say that when the service tech replaced the belt he stated that the felt tumbler seal should be replaced. I did not do so, and the dryer ran okay, but then after a time the dryer stopped and the motor would make the same buzzing sound ,but not start. So I replaced the felt seal. Any tests on the motor that do not require electrial guages, etc?
#6 Posted : Saturday, September 19, 2009 1:16:50 AM(UTC)
Not really. Only one I know of is spinning the armature to see if the bearings are shot and the following:
http://www.applianceaid.com/may_motor_dryer.html
Guest (5)
dryer wont run (Dryer Repair)
by gjack45pac 11/28/2015 9:40:28 AM(UTC)
by patriots 4/26/2015 10:21:36 AM(UTC)
Maytag Dryer wont run, burnt red wire from timer to temp control (Dryer Repair)
by Hurricane 9/4/2014 10:41:37 AM(UTC)
Kenmore HE4 Front load Dryer wont Run (Dryer Repair)
by hunterhutch 12/23/2013 6:19:04 AM(UTC)
dryer wont run control panel lights up (Dryer Repair)
by bobbijo 8/11/2013 2:13:57 PM(UTC)
Dryer wont run (Dryer Repair)
by wtester 12/3/2012 3:20:38 AM(UTC)
by jlp10 5/31/2011 4:34:08 PM(UTC)
by indybassin 2/21/2011 1:17:15 PM(UTC)
Maytag electric dryer wont run (Dryer Repair)
by crotonoil 12/9/2010 1:40:55 PM(UTC)
by latj 5/26/2010 5:11:49 AM(UTC)
by jgiff@att.net 1/25/2010 6:33:35 AM(UTC)
Maytag dryer wont run (Dryer Repair)
by Dennisb 1/5/2010 2:14:39 PM(UTC)
dryer wont run after making squeaky noise (Dryer Repair)
by pattie 9/18/2009 10:59:40 PM(UTC)
dryer wont run at all (Dryer Repair)
by neighbor 9/16/2009 7:04:39 AM(UTC)
by danielle 10/22/2008 5:55:37 PM(UTC)
