hvs
#1 Posted : Tuesday, September 15, 2009 9:07:05 AM(UTC)
hvs
I just had a repair person out and determined that my timer # AP2973903 is bad. The T-W contacts are not closing. The wiring diagram shows that they should be in the closed position for all cycles. If I jumper them together, it seems to work fine. Of course, the repair guy could not suggest this and is getting me a price on, what I'm sure, will be an expensive timer. Can you tell me if there is any problem with permanently jumpering the T and W contacts?
sidfink43
#2 Posted : Wednesday, September 16, 2009 6:50:18 AM(UTC)
sidfink43
The timer diagram I am looking at shows the T-W contacts open at the end of the cycle and intermittently in Wear Guard cycle.
I understand your desire to save some dollars, but I strongly recommend against permanently closing these contacts. You can save money by buying the timer from APP or any other parts supplier and installing it yourself. My guess is that a service tech will quote between $150 to $200 to do the job and you can do it for less than $100.00
Here is the part from APP (which I think you have already indentified)
Part number: AP2973903
hvs
#3 Posted : Thursday, September 17, 2009 8:49:14 AM(UTC)
hvs
There is no Wear Guard cycle on our dryer. On the wiring diagram, every cycle shows T - W contacts to be closed. Please review and advise.
Harold
sidfink43
#4 Posted : Thursday, September 17, 2009 9:24:58 AM(UTC)
sidfink43
Hi Harold
Again, I understand what you want to do but I can only advise you to go ahead and replace the timer. The contacts on the timer open and close for a purpose, and while it is possible that the timer you have is for multiple machines and does not use the T-W contacts on your machine, I still cannot advise you to permanently close them. A dryer can be a dangerous device, it uses a 240v circuit if electric, and produces very high temperatures. It is just not something you want to fool around with when the fix is less than $100.00.
There are places to do work arounds and save money, a dryer is just not one of them.
hvs
#5 Posted : Sunday, September 20, 2009 2:55:10 PM(UTC)
hvs
Thanks, but no thanks for your safe suggestion to replace the timer. It's obvious that you only want to sell a new timer. I have checked with other sources and have been using it as I asked about for about 20 loads now, and everything is working fine.
sidfink43
#6 Posted : Sunday, September 20, 2009 3:34:07 PM(UTC)
sidfink43
Harold
You are certainly free to operate your dryer in the manner you see fit, but to set the record straight, those of us who reply on this Forum are volunteers trying to help folks like yourself. I have no connection with APP or with any other parts supplier and get absolutely no monetary compensation with respect to this site.
I think I speak for most of us when I say we volunteer because we want to save people like yourself money on repairs that you are capable of doing yourself (and its kinda interesting trying to figure out problems). The only priority I have over giving money savings advice your safety.
I hope this works out for you.
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Dryer Timer Humming (Dryer Repair)
by terzolino 4/6/2023 10:18:16 AM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
Dryer timer shorting - help me verify my rationale (Dryer Repair)
by jeromio 1/29/2020 6:51:31 PM(UTC)
Whirlpool dryer timer knob (Dryer Repair)
by robertjhebert 10/27/2019 8:50:18 AM(UTC)
Kenmore dryer timer or no timer (Dryer Repair)
by Jester1x 10/25/2019 8:47:13 PM(UTC)
Whirlpool dryer timer won't stop running. (Dryer Repair)
by ppipowerclass 4/2/2018 2:18:22 PM(UTC)
Wiring Help On GE Dryer Timer (Dryer Repair)
by Kierancypher 6/16/2017 11:00:27 AM(UTC)
Dryer Timer Compatibility (Dryer Repair)
by Paulvolter 5/28/2017 6:48:02 PM(UTC)
dryer timer release brackets (Dryer Repair)
by lcolquitt 5/24/2017 2:50:20 PM(UTC)
Kenmore Gas Dryer Timer (Dryer Repair)
by keepitfromthedump 5/24/2017 2:18:27 PM(UTC)
dryer timer will not advance (Dryer Repair)
by Jlb86 2/24/2017 4:24:03 PM(UTC)
