buzzclark
#1 Posted : Monday, September 14, 2009 8:27:17 AM(UTC)
buzzclark
The refrig is not cooling properly. I notice that the damper door is not opening and closing. I have to manually open it and lodge a objesct to keep it open. The air is working. I just had a new fan installed in the freezer.
#2 Posted : Monday, September 14, 2009 3:35:09 PM(UTC)
Quote:
...I notice that the damper door is not opening and closing...
Sounds like the damper control has gone bad. You can run the tests as described in the Tech sheet to confirm it.
- The damper control Part number: AP4079111
Here are the breakdown diagrams and replacement part for the Maytag refrigerator Model MFD2560HES
buzzclark
#3 Posted : Tuesday, September 15, 2009 7:29:22 AM(UTC)
buzzclark
Gene thanks for the help with my damper control, you are a pro!
#4 Posted : Tuesday, September 15, 2009 6:08:49 PM(UTC)
refrig problems (Refrigerator & Freezer Repair)
by imagez 9/9/2010 12:27:07 PM(UTC)
