JDHamm82
#1 Posted : Thursday, April 9, 2009 12:51:18 PM(UTC)
JDHamm82
I just replaced broken gas valve coils on this dryer...It now will ignite, however the flame only stays lit for about five seconds before going out...This process repeats itself roughly every 30-45 seconds with the same result...This causes the dryer to not be as hot as it should be...I saw on another site that this problem may be caused by an air flow problem and i believe that the duct connected to the dryer is of the flexible foil type which isn't the best type...For years we had the plastic duct connected to it and I see lint has accumulated inside the dryer...Are there any other possible causes of this problem...I will soon try to clean any lint that may have accumulated in the dryer/duct system...Please advise me ASAP.
Thanks,
JDHamm82
#2 Posted : Thursday, April 9, 2009 2:48:48 PM(UTC)
Take the dryer apart and clean the air dusts inside and the blower housing. Make sure the blower wheel is not broken or worn out. Disconnect the vent hose from the dryer and run it without this hose. Post the results.
Here are the break down diagrams and Replacement parts for MAYTAG LDG590 | AppliancePartsPros.com
JDHamm82
#3 Posted : Thursday, April 9, 2009 3:15:09 PM(UTC)
JDHamm82
Does the blower wheel circulate the hot air into the tumbler of the dryer???...If so, I don't believe that is the problem because the is some warm air in the dryer when I run it...It just doesn't get as hot as it should...I think based on what you said that the might be a lint blockage somewhere...The lint trap is pretty beat up (this dryer is about 18 yrs. old)...Is using a vacuum to clean out the ducts o.k.???
Thanks for your help!!!
#4 Posted : Friday, April 10, 2009 11:42:17 AM(UTC)
Very possible there is insufficient air flow through the dryer which causing overheating and, as the result, the high limit thermostat shuts off the flame. One of possibilities is a blower wheel sliding around the motor shaft.
If there are no any restrictions found then possible the high limit thermostat has gone bad.
A vacuum is good.
JDHamm82
#5 Posted : Saturday, April 11, 2009 10:20:26 PM(UTC)
JDHamm82
Thanks...There was quite a bit of lint caught in the duct..I vaccummed it and now the dryer heats very well...Thanks for all of your help, Gene.
#6 Posted : Monday, April 13, 2009 12:23:59 PM(UTC)
You are welcome. I'm glad you were able to fix it.
JDHamm82
#7 Posted : Thursday, September 3, 2009 9:05:57 AM(UTC)
JDHamm82
The dryer now make a loud whirring noise when running...a repairman told my mom about a wheel that needs replacing...is this the blower wheel or something different?...PLease advise ASAP.
Thank You!
Jason H.
#8 Posted : Thursday, September 3, 2009 6:32:25 PM(UTC)
Jason,
Besides the blower wheel there are two drum support rollers and the idler pulley in this dryer. All of them can cause an excessive noise.
JDHamm82
#9 Posted : Friday, September 4, 2009 9:11:24 AM(UTC)
JDHamm82
I can't really tell whether its the roller wheel or the pulley...How would I go about replacing both of them?...and would I also have to replace the belt that goes around the drum as well?
#10 Posted : Saturday, September 5, 2009 3:09:14 PM(UTC)
The best way to save money is to take the dryer apart, inspect all parts and order the parts which are worn out. Nobody can tell you exactly what has to be replaced without seeing it.
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Maytag gas dryer flame shuts off (Dryer Repair)
by Guest 11/13/2022 11:35:33 AM(UTC)
Maytag Gas Dryer Model # MGDB400VQ0 (Dryer Repair)
by lazyacre 3/29/2020 5:29:29 AM(UTC)
Maytag gas dryer won’t ignite (Dryer Repair)
by Jmuk_98 6/30/2018 9:47:34 AM(UTC)
Maytag gas dryer console (Dryer Repair)
by thorning 5/5/2017 4:32:55 AM(UTC)
Maytag Gas Dryer Burner won't stay lite (Dryer Repair)
by tseibring 1/26/2017 2:48:45 PM(UTC)
Maytag gas dryer not heating correctly (Dryer Repair)
by ifix325 12/10/2014 6:37:45 AM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
Maytag gas dryer belt keeps coming off (Dryer Repair)
by Blurr 10/29/2014 11:17:27 AM(UTC)
Maytag Gas Dryer Will Not Stay Hot (Dryer Repair)
by jschrote 8/27/2014 6:07:26 PM(UTC)
Maytag gas dryer heats only on high (Dryer Repair)
by broooklyn 4/9/2014 10:55:14 AM(UTC)
Maytag gas dryer - flame shuts off early (Dryer Repair)
by Dcarterlaw 4/1/2014 4:52:58 PM(UTC)
Maytag Gas Dryer Timer not Adance in Auto Dry (Dryer Repair)
by modcar40 3/4/2014 3:01:27 PM(UTC)
Maytag Gas Dryer Timer not Advancing = Clothes not Drying (Dryer Repair)
by troxel 3/4/2014 6:43:42 AM(UTC)
Maytag Gas Dryer loses heat (Dryer Repair)
by editbot 2/25/2014 10:42:53 AM(UTC)
