callruss
#1 Posted : Saturday, August 29, 2009 12:13:46 PM(UTC)
callruss
Unit has no power, have checked all items on initial trouble shooting and TEST #6 on Tech sheet, have replaced both electronic assemblies, all sensors are good, thermal fuse good, still nothing lights up. One thing seems not to be normal although the schematic shows 240 on one line. When I measure voltage on L-1 to Neutral I get 40-60v, L-1 to L-2 240V, L-2 to Neutral 240v.
sidfink43
#2 Posted : Sunday, August 30, 2009 2:45:41 PM(UTC)
sidfink43
First make sure your meter is operating correctly, then re-test. Your L1 to L2 is the correct voltage, but both L1 and L2 to neutral should be 120v.
If your earlier results check out, unplug the machine and start check for some grounded wires. They are hard to find but that is likely your problem.
Good luck.
callruss
#3 Posted : Sunday, August 30, 2009 3:30:39 PM(UTC)
callruss
Meter is good quality DVM and voltages check correctly if I disconnect the power cord from the dryer and just check it at the cord connectors. I had a feeling that it was something simple, even if it was a little difficult to find. Will try to find the defective ground and let you know. Thanks.
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 6/3/2024 5:19:45 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
kenmore elite smartheat quietpak 9 control has no power (Dryer Repair)
by Guest 2/18/2024 10:39:22 PM(UTC)
Gdf520pgj2ww dishwasher no power (Dishwasher Repair)
by pbajr 8/18/2023 1:00:22 PM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE JVM1540DM5WW suddenly no power a few seconds into starting it. (Microwave Repair)
by Guest 4/16/2023 11:55:25 AM(UTC)
Fridge - No power (Refrigerator & Freezer Repair)
by Guest 1/19/2023 7:36:28 PM(UTC)
Thermador t18id900lp no power (Refrigerator & Freezer Repair)
by whosurpopi 11/15/2022 9:25:21 AM(UTC)
No power to ice and water in Frigidaire FFHS2311PFEA (Refrigerator & Freezer Repair)
by Slbno1 10/12/2022 11:12:10 AM(UTC)
lg tromm dryer no power (Dryer Repair)
by Guest 8/25/2022 8:16:12 AM(UTC)
Frigidaire FGHS2631PF4A No Power (Refrigerator & Freezer Repair)
by hpreston35 8/24/2022 2:40:22 PM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 2/2/2022 6:56:51 PM(UTC)
Maytag washer no power (Washer Repair)
by Guest 10/28/2021 12:07:08 PM(UTC)
