REBERRACING
#1 Posted : Wednesday, August 26, 2009 8:06:45 AM(UTC)
REBERRACING
The Element In The Bottom Burnt Out It Looked Like A Arc Welder Is There A Problem That It Could Have Or Did The Element Just Burn Up Thanks Jeff
#2 Posted : Wednesday, August 26, 2009 3:05:10 PM(UTC)
Very likely this is just the heating element but sometime it can be more than that. If you need the correct part number then post the complete model number of the oven.
Squirrel cage and surround broken again (Dryer Repair)
by duncang92 6/15/2024 8:36:34 AM(UTC)
Broken Roller Support for Upper Rack - Thermador DWHD770CFP/22 (Dishwasher Repair)
by Smimo4708 12/11/2023 11:28:47 AM(UTC)
Broken Wire on Door to Body Harness (Microwave Repair)
by epopper 9/24/2023 7:03:46 AM(UTC)
Fridge has Broken Wire..Where to look? (Refrigerator & Freezer Repair)
by Guest 6/28/2023 1:54:19 PM(UTC)
Broken Kenmore Refrigeration Door Pivot (Refrigerator & Freezer Repair)
by Guest 3/16/2023 8:40:18 PM(UTC)
Broken Samung Fridge Flapper (Refrigerator & Freezer Repair)
by JDWrightBrain 11/22/2022 1:20:10 PM(UTC)
The pulley on the bottom of my Maytag washer motor has broken. (Washer Repair)
by Guest 9/18/2022 9:05:55 AM(UTC)
1970 GE electric wall oven (double oven) broken temperature sensor (Oven Repair (including Ranges and Cooktops))
by zea3 6/21/2022 1:48:00 PM(UTC)
Broken worm gear in old Hamilton Beach stand mixer (36-4) (Blender Repair)
by Jidis 3/5/2022 1:21:33 PM(UTC)
Push button light switch broken (Oven Repair (including Ranges and Cooktops))
by b3853r 2/24/2022 12:40:32 PM(UTC)
Whirlpool ggw9250pl0 - broken resistor on harness...what is it? (Dryer Repair)
by jamessj1 8/23/2021 7:22:56 PM(UTC)
Broken Freezer Door Handle (Refrigerator & Freezer Repair)
by Guest 8/9/2021 11:02:12 AM(UTC)
Kenmore Induction Range - Right front & rear cooking zones broken (Oven Repair (including Ranges and Cooktops))
by Stevizard 7/4/2021 10:32:11 AM(UTC)
Less than two year old top load Maytag Washer Lid Hinge broken (Washer Repair)
by Guest 4/22/2021 7:35:44 AM(UTC)
WHRILPOOL COOKTOP GLASS SURFACE BROKEN (Oven Repair (including Ranges and Cooktops))
by Guest 4/18/2021 3:04:26 PM(UTC)
