Originally Posted by: alexandr
Sir,
I have the same problems with my BOSCH washer WFMC3200. It does not spin. Did you find out what was wrong with your washer?
Thanks.
Yes I did,. I had to change the motor board similar to what the other guy did. But first check the error codes
What you can do is put
it into a service mode to check for error codes. I'll post the directions below:
4/18/2009 Bosch FL wont spin or agitate - Appli…
…appliancepartspros.com/…/10262-b… 3/7
#8 (permalink)
1)With unit turned off, press and hold the two buttons to the left of the knob, (Spin Select and Delay - I
think)
2)While holding those buttons, rotate the knob one to the left (Perm. Press Cold)
3)Keep holding the buttons until the display shows a P:01
Now, the way Bosch's test program works is the P:XX is the specific test, and pressing "Start/Pause" will
start that test.
The tests I can recall are as follows:
P:01 - Error Code Recall
p:04 - Spin Test
P:13 - Water Valve(s) Test
P:15 - Drain Test
There are others, but these are the one's I used most ofter, therefor remember.
P:01 - Pressing start will show you an E:01 / C:0X
What this means is the E:XX is the error code and the C:XX indicates the number of times the code has
shown up in the last 8 cycles. Using the spin select button will allow you to scroll through all 24 of the
control errors as well as the motor codes, which are D:XX codes.
So, for example, if you see an E:21 / C:03 this means you unit felt there was too much foam (soap) inside
the unit,
P:04 - Pressing start will cause the door to lock, the drain to kick it and (hopefully) the unit to agitate and go
into a full speed spin. You may see an error code pop up at this point if the unit fails to spin.
P:13 Pressing starts the filling of the bleach cup. Press it a second time and the soap cup will fill with cold
water. Once more and it fills the fabric softener cup. Finally, pressing it a fourth time will fill the soap cup
with hot water. Hitting the spin select will cancel this test.
P:15 Press start and it drains.
So, using the directions above check for error codes and run a spin test. Post up your results and I'll see
what I can make of it.
