bgreen65
#1 Posted : Wednesday, August 12, 2009 10:01:50 AM(UTC)
bgreen65
Every once in a while it stops mid cycle, then sometimes it will not cut off, & keeps spining?:(
Bob
#2 Posted : Wednesday, August 12, 2009 12:56:10 PM(UTC)
Bob,
What is the complete model number of the washer?
bgreen65
#3 Posted : Wednesday, August 12, 2009 3:27:16 PM(UTC)
bgreen65
Gene, the
Model number is-MAH40000AW
Serial mumberis-53283786YH
Thanks-
Bob
#4 Posted : Friday, August 14, 2009 12:07:28 PM(UTC)
Hi Bob,
Very likely the problem is a bad timer.
- The timer Part number: AP4027283
bgreen65
#5 Posted : Friday, August 14, 2009 1:31:43 PM(UTC)
bgreen65
Thanks Gene, I now know what to look for, I will tear into it this week end.
Bob
Hi Bob,
#6 Posted : Friday, August 14, 2009 2:11:11 PM(UTC)
bgreen65
#7 Posted : Friday, August 21, 2009 12:42:05 PM(UTC)
bgreen65
I replaced the timer & it still has the same symptoms, stops in between cycles & won't cut off. What do I do next?
Bob
