Every once in a while it stops mid cycle, then sometimes it will not cut off, & keeps spining?:( Bob
Bob,
What is the complete model number of the washer?
Gene, the Model number is-MAH40000AW Serial mumberis-53283786YH Thanks- Bob
Thanks Gene, I now know what to look for, I will tear into it this week end. Bob Originally Posted by: Gene
I replaced the timer & it still has the same symptoms, stops in between cycles & won't cut off. What do I do next? Bob Originally Posted by: Gene  You are welcome. Keep us posted.
