Take a look at the parts breakdown in my earlier post.
Section 1 Item 7 is the thermal fuse for the motor Section 1 Item 9 is the fuse for the heating element |
THIS FORUM IS DEAD!!!!!!! |
Hi there, I called as per your instructions to order the thermal fuse (#7) for the motor and the fuse for the heating element (#9) but was told that #9 is a thermal cut-off and a high limit thermostat and there is no part # for a fuse for the heating element. Since you told me the problem was not with the thermostat, I did not order. Can you possibly tell me the part # for the fuse for the ehationg element? Thanks Robin
