I put the new belt on like I was instructed to, and thw washer work for about 5 loads,. But now the wheel in between the motor and the pump just spins, so it is not agitating @ all. The belt seems to B loose now. What did I do wrong????
In the diagram what number would be the roll pin be? Is that the pin that the belt go around???
Look at diagram 8, part 4
Should I remove the whole thing again first?
You should be able to determine this by observing the motor and pulley.
Originally Posted by: sidfink43  You should be able to determine this by observing the motor and pulley. OK when I took the pump and motor off I did not see a pin I thought that a set pin should B there. So if thats the case I need 2 buy a roll pin...
This senario looks very similar to mine except the pin is not broken and the pulley spins. Every thing spins freely it is just the new belt is not tight enough against the pulley to turn the drum. Help please. lwa10aw Thanks Jevon
