silk8635
#1 Posted : Wednesday, August 19, 2009 4:36:48 PM(UTC)
silk8635
I put the new belt on like I was instructed to, and thw washer work for about 5 loads,. But now the wheel in between the motor and the pump just spins, so it is not agitating @ all. The belt seems to B loose now. What did I do wrong????
sidfink43
#2 Posted : Friday, August 21, 2009 6:14:56 AM(UTC)
sidfink43
If the motor is turning look to see if the roll pin that secures the pulley (wheel) to the motor shaft is broken. This diagram should help.
Replacement parts for AMANA LWA10AW | AppliancePartsPros.com
Good luck.
silk8635
#3 Posted : Friday, August 21, 2009 6:33:57 AM(UTC)
silk8635
In the diagram what number would be the roll pin be? Is that the pin that the belt go around???
sidfink43
#4 Posted : Friday, August 21, 2009 6:36:04 AM(UTC)
sidfink43
Look at diagram 8, part 4
silk8635
#5 Posted : Friday, August 21, 2009 6:56:16 AM(UTC)
silk8635
Should I remove the whole thing again first?
sidfink43
#6 Posted : Friday, August 21, 2009 7:56:12 AM(UTC)
sidfink43
You should be able to determine this by observing the motor and pulley.
silk8635
#7 Posted : Tuesday, August 25, 2009 2:23:41 PM(UTC)
silk8635
OK when I took the pump and motor off I did not see a pin I thought that a set pin should B there. So if thats the case I need 2 buy a roll pin...
sidfink43
#8 Posted : Tuesday, August 25, 2009 2:50:11 PM(UTC)
sidfink43
jevonmorris
#9 Posted : Sunday, June 9, 2013 6:44:26 AM(UTC)
jevonmorris
This senario looks very similar to mine except the pin is not broken and the pulley spins. Every thing spins freely it is just the new belt is not tight enough against the pulley to turn the drum.
Help please.
lwa10aw
Thanks Jevon
Guest (6)
